wanted alternator
Quite a regular
wanted alternator with built- in regulater to suit nissan 1200 engine thankyou
Posted on: 2012/7/24 6:41
Re: wanted alternator
Location?
Posted on: 2012/7/24 7:01
Have you tried Wollongong Auto Parts?
In japan, 1982 and up 1200s have internally regulated alternator. Are the Australian 1200s the same?
If not, the 1980-1983 Mazda 929 alternator is same bolt-on dimensions. See
Posted on: 2012/7/24 7:06
Quite a regular
warilla nsw australia
Posted on: 2012/7/24 12:01
From Sydney, NSW
i got a mitsubishi one that bolts into the original mount. 80 amp, i can get the name of it for you to search if you want?
Posted on: 2012/7/24 14:19
Snapped crank and still smiling, How do I do it? LOL
Quite a regular
hi dion120y, yes i would like that information please thankyou regards nustat12
Posted on: 2012/7/25 1:43
Delco Remy DRA2621, used on some Mazda, is bolt-compatible with the 1200 alternator and is 50A. Not sure if it needs a longer fan belt or not, like most swaps do.
Or use Nissan 23100-B9801/23100-B9801/23100-B9802/23100-B9805 or 23100-B9810 wthich are Datsun 1200 alternators, bolt compatible, fan-belt compatible. You can buy them from nissan or from fork-lift companies.
The Mazda and the Nissan units require one to unplug the external voltage regulator and jump a couple of wires.
Posted on: 2012/7/25 2:26
I have an original one of a a14 $50
Posted on: 2012/7/25 4:00
datsun a15 ute
The A14 ones are bigger around. It is a hitachi LR150 unit?
Posted on: 2012/7/25 4:22
From A-TOWN
Got one off a low km 85 A12 $50
Posted on: 2012/7/25 6:44
