wanted alternator
wanted alternator with built- in regulater to suit nissan 1200 engine thankyou
Posted on: 2012/7/24 6:41
Re: wanted alternator
From Boredomville Melbourne
Location?
Posted on: 2012/7/24 7:01
B110 sedan: L series and 5 speeds, the way they should have been
From Seattle, WA
Have you tried Wollongong Auto Parts?
In japan, 1982 and up 1200s have internally regulated alternator. Are the Australian 1200s the same?
If not, the 1980-1983 Mazda 929 alternator is same bolt-on dimensions. See
Posted on: 2012/7/24 7:06
B110 sedan: L series and 4 speeds, the way they were
warilla nsw australia
Posted on: 2012/7/24 12:01
From Sydney, NSW
i got a mitsubishi one that bolts into the original mount. 80 amp, i can get the name of it for you to search if you want?
Posted on: 2012/7/24 14:19
Snapped crank and still smiling, How do I do it? LOL
hi dion120y, yes i would like that information please thankyou regards nustat12
Posted on: 2012/7/25 1:43
From Seattle, WA
Delco Remy DRA2621, used on some Mazda, is bolt-compatible with the 1200 alternator and is 50A. Not sure if it needs a longer fan belt or not, like most swaps do.
Or use Nissan 23100-B9801/23100-B9801/23100-B9802/23100-B9805 or 23100-B9810 wthich are Datsun 1200 alternators, bolt compatible, fan-belt compatible. You can buy them from nissan or from fork-lift companies.
The Mazda and the Nissan units require one to unplug the external voltage regulator and jump a couple of wires.
Posted on: 2012/7/25 2:26
I have an original one of a a14 $50
Posted on: 2012/7/25 4:00
datsun a15 ute
From Seattle, WA
The A14 ones are bigger around. It is a hitachi LR150 unit?
Posted on: 2012/7/25 4:22
From A-TOWN
Got one off a low km 85 A12 $50
Posted on: 2012/7/25 6:44
