H165 mini spool? Can you get them or not?
Just seeing if you can get a mini spool
instead of welding the diff up?
Cheers
Posted on: 2012/9/25 4:48
Re: H165 mini spool? Can you get them or not?
Not too shy to talk
From Sydney NSW
Just weld. H165 can take up to 200hp so it wont break.
Posted on: 2012/9/25 9:54
From Geelong, Vic
due to the way that the diff is constructed, you cant get minispools for them
Posted on: 2012/9/25 14:01
we welded the first one up was just seeing weather you could get them for it but obvisly not.
Cheers
Posted on: 2012/9/27 2:14
for suzuki diffs not problems and about the same size as the H65
sierra, jimny, carry but vitara are larger then look at suzukird.com for minispools or calmini and there are others
Posted on: 2012/9/27 3:34
so a mini spool for a sierra would fit your saying?
Posted on: 2012/9/27 9:25
thats right fit into a sierra diff not datsun!
but not sierra cosworth different car also :)
Posted on: 2012/9/27 13:59
From Geelong, Vic
so like i said in my reply, due to the way the diff is constructed a mini spool will not work. you would need to get a full spool
or just keep the welded one
Posted on: 2012/9/28 3:03
Can u get full spool for h165 mmm
Posted on: 2012/9/28 4:12
Car free
Full spool would be better
Posted on: 2012/9/29 17:05
