Need a little help with I.D on an engine
Quite a regular
From Narangba, Queensland
Hey guys,
I need a guru to help me out with I.Ding an engine I come across for sale, also, roughly what year the engine may be from?
From what I know (re: what the seller tells me) its out of a 620, has been rebuilt and modded to run ULP. I was told its an A15, but everything about it screams it isnt! Could it possibly be a J15??
Notable differences ...
Side Plates
Dizzy rearward of block almost horizontal
oil pump in centre of block (filter facing up)
head design, 3exh ports 2 intake
Cast iron head
etc etc
Casting numbers...
B82 -(under dizzy)
M - forward of the block, same side as the dizzy
5025A - Just forward of the engine mount, dizzy side
Is it worth buying, or is it a boat anchor?
Thanks guys!
Posted on: 2012/11/29 4:39
Re: Need a little help with I.D on an engine
From Snohomish, WA USA
That is interesting that the head is ported with 2 intakes for the 4 cylinders and 3 exhaust with the center one picking up cylinders 2 and 3.
It must say something on the valve cover. Start Googling.
Posted on: 2012/11/29 5:02
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
OK. That's a J Motor. If it came out of a 720 than its a J15.
Good luck with it. Up to you.
Posted on: 2012/11/29 5:11
'73 2 Door Sedan
There is an Id stamp just above the distributor
Posted on: 2012/11/29 5:20
Quite a regular
Not really an engine suited to modifications I would think? ... induction choices would be very limited with that head design i'd think?
Has anyone had much success with these engines? Im not wanting something that is going to break records, but I do want to install a cam and various other bibs n bobs ... only reason im considering this is it comes with a 4speed and the price is almost a steal.
Posted on: 2012/11/29 5:39
Quite a regular
ive only got photos to go off, unfortunately DD ... Ive been trying to contact the owner for more info like the engine number and such,it'd certainly make it alot easier, but I haven't been able to, so thought I'd get a head start ...
Posted on: 2012/11/29 6:04
From Las Vegas, NV USA
That's a J13 or J15 motor for sure. Have one in a forklift. Runs great on LPG, and reliable as they come. Hate to offer you a challenge, but good luck if you want that boat anchor to to anything.
just saying
Posted on: 2012/11/29 7:00
From Bendigo, Victoria
That's a J15. Leave it where it is, you could probably run faster than it.
They came out in 1200, 1300 and 1500 CC's. Copy of an old British Austin engine. Came out in Datsun's in early to mid 1960's. Still got a tool kit out of one I had years ago, has imperial spanners.
Posted on: 2012/11/29 7:22
Hmmm boat anchor indeed. To put it bluntly, you'd be pissing in the wind ifyou were to try get high performance out of it. Sure if you've got a spare old turbo lying around it might be a bit of fun. But don't pay more than 50 bucks for it.
Posted on: 2012/11/29 7:29
Quite a regular
pretty much summed my suspicions about this donk, it looks too industrious to be anything other than a forklift motor, the head design certainly leaves alot to be desired.
$50 was about what i was gonna pay for it, was going to be 100$ all up with the 4speed.
Which is another question, would those 4spds bolt up to A series motors? The J15 looks like it has an adaptor plate that fits to box up to it, might see if i can find out what type of 4spd it is, that'll make it easier to determine if it will I reckon ;)
Posted on: 2012/11/29 8:55
