rims and tyre scrubbing
From Port Douglas. QLD
hi folks need some help.
got to eliminate guard scrubbing on my tyres. just brought the ute and im getting rwc
done next week. tyre size is 165, 75 13inch. rims size is 13x7jj
any suggestions?
pretty sure they r 120y struts and brakes.
motor is l20b
cheers in advance.
other options i guess are new springs/shocks or new rims?
Posted on: 2013/2/4 6:24
Re: rims and tyre scrubbing
having trouble uploading pics.
gaurds are rolled too
Posted on: 2013/2/4 6:27
From Logan, QLD
different rims.
It's the rims. 165/75R13 tires do not normally rub. Do they rub on the gaurds or on the chassis? Scrubbing means rubbing on the pavement.
The normal size rim for 165s are max 6" rim (per tire manufacturer). You might make the 7"-wide rims work with spacers to achieve +30 offset.
Posted on: 2013/2/4 6:34
will 15inch trx rims fit?? i can get a cheap set of those locally
Posted on: 2013/2/4 6:35
1200 ute
ca18det
gaurds are hitting them
Posted on: 2013/2/4 6:36
1200 ute
ca18det
> gaurds are hitting [the tyres]
Then change the rims unless you want to modify the bodywork.
Tyres on TRX rims rub too.
Posted on: 2013/2/4 6:43
Where are they hitting at the top or at the front of the guards? Tyre profile helps,too 165 65 13 will help 75 is way too tall. They will be ok on rears.
Posted on: 2013/2/4 6:46
From Goulburn NSW
I had 175/70/13 on a 5.5"rim on my ute that i sold and they were fine.
Posted on: 2013/2/4 6:50
It will be his rim offset, 5'5 inch to 7 is a big difference depending on offset especially.
May have to trim the front of the guards if that's where it's hitting.
Posted on: 2013/2/4 6:53
