« 1 ... 4 5 6 (7) 8 »
Re: My CA18DET powered 1200 ute setup to run E85
From Flinders View, QLD
Well I had a little play with the harmonic balancer and a lathe. I thought I could save a little room between the radiator and the balancer by removing the first pullie. Well I thought WRONG. As I finished latheing off the first pullie I decided to clean up the face with a few slow passes and round off the outer edge. See below for the end result
jpg  BALANCER FAIL.jpg (80.63 KB)
5996_51498aeff1c06.jpg 800X600 px
jpg  BALANCER FAIL2.jpg (119.55 KB)
5996_51498b0b22934.jpg 800X600 px
Posted on: 2013/3/20 10:10
Just trying to put the bloody puzzel back together
On a good note I started to upgrade my fuel pump cradle wiring, the factory R31 wiring had gone hard/brittle plus its only like 3mm. I up graded my internal wiring to 5mm and the external wiring is 6mm. Next step is to cut off and drill out the factory steel fuel pipes and install -6AN bulkhead fittings. Then I can start running the braided teflon -6 fuel line to the fuel rail.
jpg  FUEL PUMP CRADLE01.jpg (141.56 KB)
5996_51498f2120f81.jpg 800X600 px
jpg  FUEL PUMP CRADLE02.jpg (85.94 KB)
5996_51498f2e7456b.jpg 800X600 px
Posted on: 2013/3/20 10:28
Exa ca18de come with x2 belt pulley if that helps out
Posted on: 2013/3/20 10:30
Car free
That does help supafatto, might hunt around and see if I can find one, Cheers for the hot tip.
Posted on: 2013/3/20 11:04
I inquired for a crank pulley only from one of the following links but cant remember which but wanted 100 posted to Oz. Then all you need is to machine what you dont want but I asked about a single pulley one and they said they need 10 minimum order.
Anyways just in case
http://www.ebay.com/itm/Lightweight-N ... sh=item337a9aad1f&vxp=mtr
http://www.ebay.com/itm/Nissan-S13-Si ... sh=item5ae86596de&vxp=mtr
http://www.ebay.com/itm/Racing-Light- ... sh=item20d07df886&vxp=mtr
love to mod this one to fit
http://www.ebay.com/itm/VMS-Racing-Li ... sh=item484fa3742b&vxp=mtr
Posted on: 2013/3/20 12:55
Hay D, those pullies are nice and shiney but do nothing to reduce/absorb engine harmonics as there is no rubber ring between the inertia ring and the pullies. I might source a exa pullie as supafatto says they are only 2 pully or just bite the bullet and run a 3 pully balancer.
Posted on: 2013/3/21 0:48
From Brisbane
ross make a single pulley race balancer which is very $. running one on my car.
Posted on: 2013/3/21 3:26
Ross will also make a 2 belt 20% under driven pulley for $320
Posted on: 2013/3/21 4:44
Car free
Hay oda70, the ross single pulley is a beautiful lump of alloy and steel, I'd love to have one but your right about the money, they do cost a bit, just over $500. Well worth every cent but I just cant justify that on mine, I didnt know about the ross made a 2 pulley setup supafatto, thats a little more in my price range. I will ring around and see if I can find a good 2 pulley balancer from a Exa and if not I might just go the powerbond 20% under drive 3 pulley setup, about $250 delivered. I know its 3 pulleys but I should be right for room...
Posted on: 2013/3/21 5:24
$15 bucks I paid for exa one from pick a part :)
Posted on: 2013/3/21 6:17
Car free
