differential
From sydney
is a sedan diff H145 suitable for a 1200 ute??
Posted on: 2013/5/23 9:58
Re: differential
From Perth WA AUS
Should be ok but not as strong. Best stick with the ute diff.
Posted on: 2013/5/23 10:10
Datsun 1200 2Dr sedan.
Re: differential
From sydney
it seems to be smaller too, the diff in the ute is f*****, so much backlash, i doubt its fixable but not sure?
Posted on: 2013/5/23 10:43
Re: differential
From Stone Age somewhere in U.S.A.
The 1200 sedans and coupe use H145 diffs. The ute's use H165 diffs. The inside diameter of the ute diff. is 20 mm larger, and uses a different housing. So NO you can not use a sedan diff in a ute without changing the whole assembly. Not a smart idea as the ute diff. is also stronger.
Posted on: 2013/5/23 14:54
Re: differential
From sydney
Is it possible to recondition the h165 diff then???
Posted on: 2013/5/23 22:12
Re: differential
Yes, it is possible. But more reliable and less expensive to swap in a good used H165 center unit. They were used by many Datsuns.
Posted on: 2013/5/24 0:06
Re: differential
From sydney
Where can I get a diff centre from? Or do I have to hit up a wrecking yard?
Posted on: 2013/5/24 1:07
Re: differential
Yes, the usual source of used parts is the wrecking yard. But you can also buy them from club members, gumtree, etc. Best to buy one straight out of the car, not one that's been out and sitting in the yard for years.
Posted on: 2013/5/24 2:40
Re: differential
From sydney
Ok thanks, will I need to changes the axles aswell??
Posted on: 2013/5/24 3:42
Re: differential
From Narellan,Sydney
Hey maddatter no your wont need to change the axles only the centre.spewing the sedan diff won't work
Posted on: 2013/5/24 3:44
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
