Motorcycle vs. Car Drift Battle 3 -
From melbourne
Posted on: 2013/7/3 12:02
Re: Motorcycle vs. Car Drift Battle 3 -
Could just imagine your eyes Nick :)
gif  nickstarvalvevision.gif (12.71 KB)
737_51d4dfec10d86.gif 100X100 px
Posted on: 2013/7/4 3:38
From melbourne
Just memories brother, back in the day, we use to test every summer all the new bikes straight out of the crate at Calder Raceway for write ups in magazines. But we also took our (my girls Busa 330hp extended swing arm) n my Zx12 250hp with extended swing arm. Best part was going up the on-ramp ( 360 bend) onto the Bolte Bridge and over. Normally they were like yachts to turn and had to drift !!
Posted on: 2013/7/4 7:33
From Gold Coast
That would be unreal, imagine when the bike came on boost.
Posted on: 2013/7/4 12:17
From melbourne
The Busa ate a set of clutch plates every 6 passes including the trip to Calder (most of the damage) and barely made it home. It ran a small GT turbo which was off my cbr600 (201hp 9psi). ZX 12 however was not turbo but worked off its nut and a shot of NOS. Cause I weigh about 86kg and my girl weighed about 46kg , we worked out she had about 25-30hp advantage over me just there. She had an amazing reaction time of .003-.007 and I was 1. upto whatever. But I would have her from the start and upto the last 70m and then you'd hear that turbo on ya asss. I use to hit the NOS in 4th but made no difference all you'd hear was TURBO coming. I think she use to back off towards the end cause she felt sorry for me. I only beat her once out of about 100 runs due to her going sideways and missing a gear.. And I just just beat her. The other interesting fact was I ran a concoction of avgas- methyl benzene (toluene) 20% and nitro ethane 5%. Think the Tol was there cause the nitro wouldnt mix (immiscible) with the avgas and made it mix. Not really sure how it works but did get an extra 16HP just from the fuel !! If you were to ever put a bike engine in a Datto, I'd definitely go the Yamaha V-Max. Super tough motor with a super tough gearbox and so much grunt. Flat 10 's straight out of the create and so much bolt on stuff available.ZX12 would be 2nd choice, such a good motor with a constant mid to low 10's. Busa has #OOPS#t motor, never ending problems and same as Zx12 mid to low 10"s.
Posted on: 2013/7/5 1:46
Edited by nickmitty on 2013/7/5 3:22:00
zx14 has stronger box than zx12 but i wished I bought the zx12 head its a better unit than the zx14, flows better and head bolts have a consistent lay out. zx12 head is used on the kawasaki zx15 supercharged jetski 1.5 L 300hp. The zx15 engine is like a car engine check it out very different sep gearbox to crankcase. Vmax motor is awesome but heavy 130kg with box double zx15 & zx12/14 with box. honda v4 1300cc is normal V config Vmax unfortunately sideways but Vmax is the awesome motor in everyway love a vmax trike :)
Posted on: 2013/7/5 1:58
From melbourne
Yes D the ZX14 is an amazing bike, real low center of gravity. Slightly shorter wheel base which makes it turn better. And it will go as hard as you can twist the throttle !! And grunt !! Pick a gear any gear and its off
Posted on: 2013/7/5 2:04
