Re: ca18 gearbox
I also have a short shift kit for my 71c box
Posted on: 2013/7/31 15:18
Car free
Re: ca18 gearbox
So what do you guys with ca conversions think is a strong box
Without modding tunnel?
Posted on: 2013/8/1 1:54
Re: ca18 gearbox
You need to mod the tunnel unless its an auto tunnel then might just need a little massage. If you got access to a hoist you can get underneath and use a short hand sledge hammer with some flat wood and stretch it from underneath. I did this to an early K series corolla to fit a bigger W series box.
No box will fit thats small enough for a CA otherwise
Posted on: 2013/8/1 2:49
Re: ca18 gearbox
Ok so moddinh the tunnel is a must. Then just ca gearbox is good enough for about 300-400hp?
Posted on: 2013/8/1 2:59
Re: ca18 gearbox
From Narellan,Sydney
400hp dosnt mean Much to a gear box but it depends how hard its flogged and thrown threw the gears.thats what break them most the time
Posted on: 2013/8/1 3:30
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: ca18 gearbox
From Goulburn NSW
Hi guys I also have a ca18 5 speed and as mentioned before will be starting out with 300hp minium then will be going up from there.So im wondering whether or not I should just go auto and not have to worry about it in the long run.
Posted on: 2013/8/1 3:46
Re: ca18 gearbox
Do you want to drive auto or manual? That's wat it comes down to
Posted on: 2013/8/1 5:49
Re: ca18 gearbox
From MOOROODUC. Victoria
An auto can still break, but they are cheaper to buy
I had an auto 1200 trans tunnel welded in and it was still not big enough for the CA18 auto box. There was still some manual massage-ing that i had to do
Posted on: 2013/8/1 5:57
Re: ca18 gearbox
From Goulburn NSW
Yeah im not talking about ca auto,im talking jatco or something along the lines off c4.
Posted on: 2013/8/1 6:36
« 1 (2)
