what A/f ratio on E85
From melbourne
Hi guys,
I am about to switch my turbo a12 with a stock bottom end over to E85, can anyone advise what a safe E85 ratio is on 15 pounds boost as im getting mixed feed back
cheers anthony
Posted on: 2013/12/17 7:36
Re: what A/f ratio on E85
Safe air/fuel ratio is a range. It will be safe at more than one specific ratio. Just don't let it run lean.
Posted on: 2013/12/17 9:05
From Narellan,Sydney
I hope your also redoing your whole fuel system mate.lines,pump,filters etc otherwise the ethonal will just eat away at everything
Posted on: 2013/12/17 12:04
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
From melbourne
No i wasn't changing anything I was going to run the E85 and rubber lubricant
its working fine with mmy friends E85 set up and yes i have asked him about E85 safe ratio, he said E85 has a rich power number and lean one BUT his numbers are different due to forged pistons,large cams (changes in dynamic pressure) ect So that why i was asking here thought there mimght have been a few in the same boat std motors,boost and E85
most tune the A/f on 98 a little fat at 12-12.5 so im going to Aim for .82 on E85 which is roughly around 12 on the petrol scale see what happens
Cheers for your help guys
anthony
Posted on: 2013/12/17 21:17
From Melbourne,Australia
Get in contact with Simon (sikyne) on here he has a heap of experience tuning E85 especially on turbo a series engines.
Posted on: 2013/12/17 21:26
From Brisbane, Australia
typing "e85 AFR" into google will give you all the information you need...
Ethanol is not corrosive like methanol is, so don't worry about it "eating everything away".
Posted on: 2013/12/17 22:14
Don't be surprised if your pumps eventually fail.theres a reason they make specific e85 fuel pumps and line.but if you want to keep costs down them try your luck
Posted on: 2013/12/17 23:01
From melbourne
cheers L18_B110 i will do i have a great table my mate gave me changes 98/e85/alch to lambda and a/f ratio
trb012 I was going too,but didn't want to bug the chap as im sure he answers quite a few... :)
Thanks for the speedy responses cheers
Posted on: 2013/12/18 0:28
Yeah he's a busy man but always happy to help he tuned my Z18 on E85
Posted on: 2013/12/18 0:43
From Adelaide
You can check the Cole Palmer materials database to check compatibility with ethanol and toluene (close enough to petrol). Generally ethanol is one of the more gentle chemicals. It's fine with most rubbers. It is hygroscopic (means it sucks water out of the air), pretty much just means its best not to leave it too long. I doubt you'll have any problems. Best approach is just run with it and keep an eye on things. Upgrade if you have problems.
Posted on: 2013/12/19 1:10
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
