Sr20det gearbox with ca18det bell housing
From Goulburn NSW
Hi guys are the bell housings interchangeable on these two gearboxes?i have a ca18det 5 speed and was going to put a PPG kit through it but they don't do them anymore so the plan now is to get a sr20det gearbox which they do the kit im after and is rated at 600hp,then swap the bell housing with the ca18det one.Is this an easy change?
Posted on: 2014/6/19 10:17
Re: Sr20det gearbox with ca18det bell housing
From Sydney
Yes make sure it's from either a s13 or s14, from experience with a mates car that did this swap the s14 is the better box.
Posted on: 2014/6/19 10:24
From Geelong, Vic
Bellhousings are interchangeable yes. All silvia boxes are externally the same (other than 6 speed)
Posted on: 2014/6/19 11:52
From Canberra
my understanding is the only difference is the bellhousing between CA and SR 5 speed.
Later 5 speeds had a difference sandwich plate design..... happy to stand corrected though
Posted on: 2014/6/19 13:58
From Geelong, Vic
What 5 speeds are later? S15 is still the same box as s14 im pretty sure
Posted on: 2014/6/19 14:03
I thought s15 were 6speed and not as strong as the 5
Posted on: 2014/6/19 22:55
S15 came with 5-speed FS5W71C. Optional was 6-speed FS6R92A or Automatic.
Posted on: 2014/6/19 23:34
S13/S14 used 71C gearboxes
* S13 SR gearbox
* S13 CA gearbox
* S14 SR gearbox
They don't have a removable bellhousing. Instead its integral with the Front Case. By partially disassembling the gearbox and swapping the front half of the case it can be used on the other engine .
Posted on: 2014/6/19 23:35
From Goulburn NSW
Well guys it looks like that everything that has been discussed is now out off the question,$12,500 for the ppg gearset for the sr20.So now will look into rb25det,can they handle a lot off hp?
Posted on: 2014/6/20 1:35
Yes, the RB25DE can handle a lot off hp (there was no RB25DET).
Posted on: 2014/6/20 1:49
