Re: Bad vibration A15 when reved
Not too shy to talk
From Newcastle
That should have said pulled an L20 apart
Posted on: 2014/7/29 2:40
From sydney australia
Could be a badly balanced flywheel, all the way through to a cracked crank (bought one of those once). Or maybe the clutch plate is worn badly or it's the pressure plate. Hopefully for you it's an accessory like an alternator bearing, or a broken mounting bolt you just haven't found yet, like the alternator bolts.
Posted on: 2014/7/31 11:43
From brissie
Has to be internal on motor. As I have started motor up with clutch and pressure plate removed and fan belt removed and free reving the motor still has vibration.
Posted on: 2014/8/7 7:45
A12,4spd, mild cam ,head work, mags.
Could be out of balance flywheel
Posted on: 2014/8/7 8:06
From melbourne
Have you checked compression and valve clearance and that all spark plugs are firing...?
Posted on: 2014/8/8 1:40
E85 Turbo 120y wagon Built not bought........
« 1 (2)
