Bluebird diff center in 1200 ute?
From NSW, Australia
Gday, i just wanted to confirm when installing a 3.9 ratio bluebird diff center in my 1200 ute if i will need a shim or not and will the 1200 ute axles be ok? i had a look in the tech section but i cant find and confirm these two questions.
Posted on: 2014/8/5 2:29
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Bluebird diff center in 1200 ute?
Can't give you a real technical answer but I think there were three variations in the Bluebird diffs
and I used one from a series II Bluebird in my previous ute and it just bolted in and no shimming or axle changes required.
Have a look at below web page:
http://martybugs.net/DatsunMods/diff.cgi
Posted on: 2014/8/5 4:29
From Sydney
If its the H165 centre, its a stright swap. the series III had the H190 rear end
Posted on: 2014/8/5 5:24
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From NSW, Australia
Awesome! thank you
Posted on: 2014/8/6 12:15
Cheers,
Big D
