Ga head flow compared to A series
From Bridgetown, Barbados. W.I
Does the ga flow more than A series?
Posted on: 2016/1/23 12:49
Life's better SIDEWAYS!!
Re: Ga head flow compared to A series
GA is a 16-valve head that makes 115 hp
A-series is 8-valve and the top head makes 83 hp
Posted on: 2016/1/23 19:29
Of course that's only the top GA head (GA16DE DOHC vvt). GA heads came in lesser SOHC versions and even small-bore carbureted engines. The hi-power head in the B14 head with Nissan-VCT, you can switch from low-RPM cam to high-RPM cam using a dashboard switch.
Posted on: 2016/1/23 22:26
A yank publication sometime back showed the GA16DE Head ported is up to 80 - 85% the CFM of the best SR20DE heads. In turbo form also down 15-20% a bigger capacity SR20DE with similar turbos and injector setups.
Does it flow more than an A series? any 16v head should be able to.
Peter Zekert is using a whole ga16de setup in their next race car 1200 and says its almost as light as an A15
Posted on: 2016/1/24 2:46
So is it possible to build a 180 HP (flywheel) ga?
Posted on: 2016/1/26 15:05
From Creswell, Oregon USA
I would love to build a GA16DE for the coupe.
Posted on: 2016/1/26 19:17
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
So do it. $190 at pick'n'pull -- already built. Bolts to your A14 transmission.
So is it possible to build a 180 HP (flywheel) GA? Certainly. Project 200SX got 252 hp.
Posted on: 2016/1/26 21:53
400.00-1000.00 local :(
Posted on: 2016/1/26 22:52
Parler @MDMachine
Pick-n-pull Oregon only charges 189.99 for a fuel-injected engine
Posted on: 2016/1/26 23:21
I am looking at B&R, but I think Pick N Pull is up on hwy 99 north of Eugene.
Posted on: 2016/1/27 1:32
Parler @MDMachine
(1) 2 3 4 »
