Front disc rotors 1200 1985 ute
Hi need help with front disc info for 1200 ute 1985 mod
should these be 212mm (DR314) or 219 (DR310) i got a pair or 212mm but the disc is
to small on the od,as the pads hang out past the od (DB39)pads
past the rotor, it looks like i need the 219mm, 120Y late.
Is this correct as the DR310 219mm disc has a different off set
i can't find any 219mm ?? any info on a supplier
Regards Mark
Posted on: 2016/8/13 15:54
Re: Front disc rotors 1200 1985 ute
1985 ute came with drum brakes, so it seems sometime in the last 30+ years they have been swapped for disc brakes. 212 and 220 are the common sizes used, but really anything can be swapped. Can you post a photo of the pads? It may help us ID the rotors
The 220mm rotors (some suppliers sell them as 219mm) are from 1976-1978 120Y
Nissan part number 40206-H7500
* B210 1976-1978 w/12" wheels
* B310 1979-1983 w/12" wheels
* Yulon 303 (Taiwan) w/12" wheels
Posted on: 2016/8/13 21:22
Yes I have an 85 ute and it was equipped with drum brakes originally. I've since fitted 120y struts and S13 calipers and rotors.
Maybe you should take your worn rotors into a brake shop and see if they can find the correct replacement for you.
Posted on: 2016/8/14 3:19
120y pbr disks are very hard to find, we did an oz wide search and turned up nothing, you will struggle I think. I'd option to the s13 brakes
Posted on: 2016/8/14 12:24
Car free
Yes, a good time to convert to S13 Brakes
The 220mm disc rotors are Nissan, and they are used with PBR calipers (on Australia-assembled 120Y) or Nissan calipers on Japan-assembled 120Y coupe
Posted on: 2016/8/14 12:30
From Fremantle, West Australia
Hi Mark
I will bring some 120Y PBR discs down to the workshop Wednesday
Posted on: 2016/8/16 15:28
