Any good aftermarket parts outlets in the US?
From Burbank Ca.
Hard to find parts for the A series motors here. Any ideas?
Posted on: 2004/7/6 16:34
Re: Any good aftermarket parts outlets in the US?
From Burbank, CA
what kind of parts are you looking for. there are some parts around, www.nismoparts.com/ has a 210 performance section and they still have parts.
I see you are in burbank too! I work in burbank over by the cost-co.
Posted on: 2004/7/6 18:18
From Burbank Ca.
Main thing at this point is dual valve springs. I tried contacting Crane, but they dont return my calls. I had a set from my cam grinder, but they were a hair too big in diameter so they were binding. I am running stock ones at the moment. I think I need more pressure for the cam im running.
Posted on: 2004/7/6 22:49
From Burbank, CA
Nismo parts for datsun 210's
did you try www.datrats.com.au? they might have something. I know i's not in NA but they seem to have good items.
have you tried the datsun 210 group on yahoo? there are mor people in the US on there and they might know of a source for the valve springs... I'll ask.
Posted on: 2004/7/6 23:02
From Castro Valley,CA USA
Jegs - example valve springs
I'm not positive, but I think my valve springs are the SB chevy 1.255 OD size. The guy who rebuilt my head cut the valve spring seats a little wider to fit. Modified just slightly for more readily available parts.
edit-
Crane Cams
not for A series, but close
edit again - This is what happens when I respond without reading all the posts.
You may be able to enlarge the valve spring seats or base to fit the Outside Diameter of the springs your cam grinder recommended.
Posted on: 2004/7/7 0:07
From Burbank, CA
Since you are in Southern California...there are 2 places you can get
them from...One is on Broadway St. in Gardena...right in the corner
Isky cams and the other one is by the Ventura Freeway...Damn...I can't
remember exactly their address at the moment...But I'll post it by
tommorrow afternoon!
Leosnake > from datsun210 - group on yahoo
Posted on: 2004/7/7 1:34
From Los Angeles,CA. USA
Damn B210sleeper...you must have DSL and have 2 navigator windows open at the same time...I had just typed that message not more than a minute ago!!
Posted on: 2004/7/7 1:46
Have you seen the Parts Sources article?
Posted on: 2004/7/7 4:17
From Burbank, CA
heh.. actually I do, Safari on a dual head mac, so i have 4 windows each with many tabs and email too.
Posted on: 2004/7/7 18:22
Well here is the information for locating A-series parts in the Los Angeles County:
Top End Performance
7452 Varna Ave.
North Hollywood, CA 91605
818-764-1901
I bought my springs and stainless steel valves off of them...I also had them do the machine work on one of my A14 and L24 cylinder heads.
Posted on: 2004/7/7 20:50
