A12 gx cam shaft on ebay USA Not mine---- Yet :)
From Selah, Washington
Opening bid of $89
These wont work in an A14 ?
EBAY
Posted on: 2006/2/8 9:29
Re: A12 gx cam shaft on ebay USA Not mine---- Yet :)
Nah wont work in A14 if you plan to run a distributor in the stock position. Its missing the gear to drive it.
Posted on: 2006/2/8 9:35
These will fit & work in A10 & 1200 engines only. [up to '73]
Posted on: 2006/2/8 11:01
Love your Datsun.
Treat it well.
So are you saying this camshaft wont fit in a 74 and up A series and bump the pushrods to open the valves? I have always been led to believe it actually will.
Posted on: 2006/2/8 11:18
Hmmm
Posted on: 2006/2/8 12:45
phunk who did that to the id tag?
Posted on: 2006/2/8 13:13
I just went through ebay searching for 1200 stuff & this did not show up in the search. What gives?
How do you guys search? I look under 1200,110, B110 etc.
Posted on: 2006/2/9 1:41
From California
this thing's not any bigger than an a15 cam I bet
Posted on: 2006/2/9 4:31
So proclaimed silent E, will this cam fit a 74 and up A series or not. I know the answer and I posted it in my first reply. I just want to see you say it, as the following is a big statement. Quote:
Did what?
Posted on: 2006/2/9 7:12
From Castro Valley,CA USA
Ebay "Datsun 1200" and it should be there.
Speaking of cams, if you have a cam that you want "copied", is that possible? By copied I mean using a cam as a master as opposed to using a normal master cam. I have no idea what cam grinders use as Master cams.
I used the word cam 7 times
Posted on: 2006/2/9 9:01
(1) 2 3 »
