Is this Sedan Or Coupe ?
From Sri Lanka
Hi guys
Let me to Clear, is this Sedan or Coupe ?even though i am using i have no clear idea
On
http://datsun1200.com/modules/myalbum/viewcat.php?uid=-1
Or
Go to Photo Album -- Misc-- Page 6595
Thanks
Regards
Sumith
Posted on: 2008/12/29 10:53
Re: Is this Sedan Or Coupe ?
From Invercargill, New Zealand
Hi Sumith - that is a 120Y or B210 Sedan.
Posted on: 2008/12/29 10:58
From Sri Lanka
Hi,
You may be right This is B210, i was unclear about sedan or coupe ? it should be sedan i also guest so .
Thanks
Regards
Sumith
Posted on: 2008/12/29 11:09
http://datsun1200.com/modules/myalbum/photos/6595.jpg
This picture is of B110. It is of Sedan. Coupes always came with round-gauge dashboard.
Posted on: 2008/12/29 17:10
From Sri Lanka
Hi,
My Dash Board is also round gauge Dashboard , so is it coupe then ? or are there Sedan came with Round Gauge Dashboard ? or it has been changed early to the Round gauge Dashboard ?
Thanks
Regards
Sumith
Posted on: 2008/12/30 3:49
B210 sedans came with square gauges mostly, except *some* GX models. Most B210 GX sedan had rectangular.
Send me the information on the engine-compartment ID plate, and I can tell you more. There may also be a build plate on the door sill. Date, serial number, chassis type. You can find chassis/serial stamped in the sheet metal above the wiper motor.
Posted on: 2008/12/30 4:00
From Sri Lanka
Hi,
Let me to send you a photo of dash board, ill see the plates also and let you know, My GX is in Paint job, it is bit far away , ill send those info when i get it , Thanks for the help
Thanks
Regards
Sumith
Posted on: 2008/12/30 4:17
I looked at this photo which I presume is Sumith's car - Car at painters
Is this your car Sumith?
Posted on: 2008/12/30 5:09
From Vancouver BC Canada
Datsun called the 2 door hatchback the coupe and the 2 and 4 door with the trunk a sedan.
The car in that pic has a trunk and is either a 2 door sedan or a 4 door sedan, it is difficult to see how many doors this one has.
The sedan was also the only body with the rear light assembly that came to a point on the outside.
Posted on: 2008/12/30 7:29
If at first you don't succeed, lower your standards.
Keith (Mac-Datty)
2-dr Sedan did not come in GX trim. So it must be a 4-dr sedan.
Posted on: 2008/12/30 7:42
