Can I use anything?
Quite a regular
From Dubbo, NSW Australia
Hi guys,
Will anything from a 1984 Datsun Bluebird fit on my 1980 1200 Ute?
I have my eyes on the diff, but I didnt have any means of measuring it up when I was crawling over this wreck. Does anyone know if the diff at least, or maybe more, will fit?
Thanks
Wayne
Posted on: 2002/11/10 13:37
Re: Can I use anything?
From Melbourne, Australia
diffs too wide! unless you use fwd offset rims or flare guards, brakes will fit on your axles if you think there better, some had disc over drum but only fit under 14"wheels otherwise all good, the u bolts off the diff are looong so if you plan to put lowering blocks these are good, the diff centre will fit your diff, thats about it i think as far as the whole car goes
Posted on: 2002/11/10 13:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
