Any larger non-datsun alternators fit?
From Burbank, CA
Are there any easily adapted alternators from other cars? I just need a replacement for my 60a sunny alternator and wanted to know if there are any larger ones that are easy to install.
Posted on: 2006/3/8 2:08
|||\ 81 KPB310 /|||
Re: Any larger non-datsun alternators fit?
Sure, can do. Do you just want to add weight, or do you have a need for 100+ amp output?
Here's an outline for using an old-style Chrysler alternator on a A14.
The newer 100 amp units are smaller.
Alternator Upgrade
Posted on: 2006/3/8 2:29
From Burbank, CA
just curious, I suppose the only power draw is the headamps and the amp for the stereo and the big electric fan. Really a 60A sunny alternator is fine. Just thinking a bigger american alternator might be cheaper, but space is tight up there where the alternator is.
Watts / Volts = Amps, ya? i'll see how many i need. how many are used for charging the battery typically?
I should have 13+ amps left for battery charging on a 60A alternator. But I want to add maybe another 150watts of stuff more. which could leave as little as .5 amps to charge the battery if everything was at 100% but that would probably never happen.
Posted on: 2006/3/8 3:10
|||\ 81 KPB310 /|||
I added more swap info to the Wiring article in Tech Section.
Posted on: 2006/3/8 23:17
From Burbank, CA
if i had a spare lower mount to hack on i might try it. Or if i were to try the oldskool lower mount on the drivers side. Maybe. It's not going to be a bolt in thing. so it'll have to wait.
Posted on: 2006/3/9 1:03
|||\ 81 KPB310 /|||
