exhaust rubbing after lowering blocks taken out
hey guys,
finally got the coupe back, took it to a mechanic to get roadworthy, the 2.5 inch lowering blocks were taken out and now the exhaust is rubbing against the diff or something... how much should i expect to pay an exhaust fitter to heat up the 2 inch exhaust and bend it a little to stop this awfull rubbing rubbing sound?
Posted on: 2006/3/13 3:34
Re: exhaust rubbing after lowering blocks taken out
From Melbourne AUS
generally the minumum fee for getting your car up on a hoist and doing something to it is gonna be around $70..
my advice would be to get underneath it and have a look.. it may be a simple fix that you can perform yourself if you have access to the right tools
good luck
Posted on: 2006/3/13 3:44
1973 B110 A12
From Tas
You'll probably find that it's just a matter of literally giving it a pull away from the body (no heat involved). You'd be surprised, it's most likely what they would do if you took it somewhere especially with exhausts. Sometimes the only way to fix little annoyances is to get brutal (but gentle at the same time).
I've been there first hand adjusting doors to line up on $80,000 + cars and trust me, if the owners could see, they would be horrified. But end result is the same as long as you know what you're doing.
Posted on: 2006/3/13 5:39
From Townsville, Qld
I know a place you could bring it during the week and have a look at it...
Posted on: 2006/3/13 6:17
HAHAHAH! yeh mate, the dude who sold it to me has kept the plates and hasnt unregistered it yet, so i gotta wait till he gets off his backside and deregisters it or i gotta wait till the 22nd till i can register it, its been a pain in the arse... but when shes on the road ill definetly bring her over for a look see!
ok, i tried pulling it before i posted and yeh its not going into place, i was thinking of just getting some steel strapping and wrap it round the exhaust where its hitting the drive shaft and pull it away and attach the strapping to the bolt that comes out the floor from the seat (its the closest thing i could attach it too) does anyone see any problems in doing this??? i rekon it should work the trick, but i would like to know if anyone has tried something similar and their results with it??? thanks!
Posted on: 2006/3/13 7:56
From sacramento california
you had 2.5in lowering block on your 2door? i am planning on adding some lowering blocks. would you happen to have a picture so i can see how a 2.5in slammed datto looks? im not sure how low to make it though.
Posted on: 2006/3/13 9:22
i can send pics, wats ur email??? yeh it did look tuff before i took them out... they most likely going back in after rego
Posted on: 2006/3/13 10:34
my email is casper17000@yahoo.com thanks!
Posted on: 2006/3/13 10:38
