« 1 2 (3)
Re: Alternator wiring
From Brisbane
Can I just have a wire with fuse on it and how many amps for the fuse do I get?
Posted on: 2006/3/18 0:21
You can replace the stock fusible link with another link or fuse of any type that meets the requirements. This is discussed in the previously mentioned "wiring" article.
Posted on: 2006/3/18 3:27
From Brisbane
it doesnt say or I missed it how many amps or rating that I can use for the replacement link
what is the stock amp rating of the fusible link?
Posted on: 2006/3/18 7:04
It's not the amp rating you need to worry about, it's the fusing rating.
Use a "FUL 0.5mm2" or better fuse-link.
. There are more details in the article.
Posted on: 2006/3/18 8:24
From Brisbane
found these
Here are standard Nissan "Pacific" wire colours, their rated melting currents, and cross sectional area:
(Thanks to Wayne Monteath for uncovering this rare table!).
Pink 30 amp
Green 40 amps 0.50mm
Posted on: 2006/3/18 8:35
Man these threads are a crack up.
You have an XXamp alternator and you cant work out what size fuze is required for the power.
Maybe its the battery. Yeah needs a new battery.
Posted on: 2006/3/18 8:52
« 1 2 (3)
