flywheel bolts coming loose. a15/120why
they came loose not long after i put my a15 in.
i tightend the #### out of them.
last night they come loose again.
the bolt holes in the flywheel are now 0 instead of o.
i have another fly wheel to put on once i get it refaced and balanced. is it worth getting it lightened while at the balancing place?
why has it come loose? are you suposed to use loctite?
the engine is stock with 32/36 webber and extractors into 2 inch system.
i wouldnt think it would be making flywheels come loose!
a lot of questions i know.
but i need the advice.
cheers, nate
Posted on: 2006/3/21 8:38
Re: flywheel bolts coming loose. a15/120why
From sydney
Yes use Loctite.
How high were you revving it?
Posted on: 2006/3/21 9:26
From sacramento california
im not sure, but i think if you overtightened them then they would come lose over and over without thred locker like loctite. what holds the bolts in place is when they stretch from being tightened. if they have been overtightned then they might lose their ability to grip the threads. this could be your problem, in which case just replace the bolts and use loctite red.
Posted on: 2006/3/21 9:34
From Warburton vic
yes use lock tight.
Tighten them to manufactures specs & you wont have a problem. If it happens again dowel the crank & fly wheel
Coops
Posted on: 2006/3/21 11:06
From Perth
Posted on: 2006/3/21 11:18
From Sydney, Australia
thanks dattoman_1000. We sure have been here for too long. I knew we'd talked about this before.
Coulda put it in google too
["flywheel bolts" a15 loose]
Posted on: 2006/3/21 13:56
