Z18 Turbo motors, are they any good??
A friend has a Z18 Turbo motor and box and wants to fit it in a little datsun, not sure which one yet.
We just want to know if they are a reliable unit??
Posted on: 2006/3/27 7:09
Re: Z18 Turbo motors, are they any good??
From Melbourne,Australia
Very reliable and strong basicly an L18 with a crossflow head so parts are pretty easy to come buy.Also depends on what you want to achive out off it as well if your chasing big power your better off starting with an sr20 or fj but in saying that im hopeing for a reliable 150kw at the wheels once im back on the road which is plenty off power to fling a lightweight datsun along
Posted on: 2006/3/27 8:59
The smallest are the Datsun 1000, Datsun 1200 and Datsun Cherry E10. These weight hundreds of pounds less than other Datsuns (especially B210s).
The L18 and Z20 can definitely fit in a 1200 under the stock bonnet if carefully done, so it seems the Z18 would fit.
Z18T engine
Z18T engine in B210
Posted on: 2006/3/27 23:46
Quite a regular
From australia
i dont see y it want fit they r only a small engine.me nefu has one in a 720 ute and u could get in and walk around it in there.they r allso fairly quick the ute dose 12.5 sec down the strip
Posted on: 2006/3/28 4:41
From Tamworth, NSW
Does any one know the weight of the z18? in comparision to a ca18. they look good from a cost point of veiw.
Posted on: 2006/3/28 10:11
Project coupe:
Just drive it
Quite a regular
From australia
lol they weight #### all hey go very hard for a small motor i bet they r lighter than the ca 18
Posted on: 2006/3/28 16:01
Z18T and CA18DET weight just about the same (see Engine swap tech section article, at the end). However, the CA18DET is a higher revving DOHC design and made 190 hp vs 150 hp in the Z18T.
The SR20 is the weight hog. The QR25 is a better engine than the SR20, it is lighter and with more HP. But the SR20 has readily available tuner parts.
Posted on: 2006/3/28 22:43
