« 1 (2)
Re: A series 1/4 mile time
what would a 1200 wagon
A15 full turbo worked run?
Posted on: 2006/3/29 10:14
From Stray-ya
I think you might want to have a look at this little presentation- it was developed for another forum but the principles are the same
http://albinoblacksheep.com/flash/posting.php
Posted on: 2006/3/29 10:59
From Brisbane, Narangba
In the 14s bracket id assume or a somewhere in the 13s mark if you went crazy. (big$$$)
I mentioned this once before. A story my uncle told me who is a an engine reconditioner. They built and a15 for this guy. He had custom forged pistons and rods. Good rod bolts, headstuds and head gasket. Shotpeened crank, o-ringed block and my cousin did the headwork. Massive valves, double valve springs and alot of hours playing around with the flow numbers. Supercharged, fuel injected with a carefully thought out cam. To end the story it ran a 12.7/ (sorry cant remember mile an hour) Lots of dollars though but i think this proves the A-series worthy.
Posted on: 2006/3/29 11:00
Try this calculator: http://www.rpmoutlet.com/dyno.htm
For a Datsun 1200 with A14/A15 engine, say 1660 pounds. 150 pound driver (total: 1810 pounds). 120 gross HP which is maybe 90 rwhp, the calculator says estimated ET of 15.8 seconds. For 120 rwhp, it's 14.4 seconds.
Posted on: 2006/3/29 20:26
Here's some 1/4 miles times. Seems Ron in Hawaii is now running a KA24(?) turbo running at 11.9 seconds. Compare that to a mild na KA24DE at a reported 13.99.
Those engines are twice as big as an A12.
http://www.dragtimes.com/Datsun--1200-Drag-Racing.html
Our old friend Luis is now running 9.000 @ 149.000 in the 1/4 mile.
Posted on: 2006/4/8 6:10
From Burbank, CA
why do b310's have to be so heavy!!!
a 1200 is like 400 lb lighter.
Posted on: 2006/4/8 7:33
|||\ 81 KPB310 /|||
From BRISBANE NORTHSIDE
My ute A15 cam SU,s 15.8.
No 4 son,s sedan A15 cam Weber,s 15.3.
No 2 son,s ute A15 cam weber,s 14.4.
No 4 son,s sedan L20 cam weber,s 13.1.
No 2 son,s wagon SR20 det 9.79.
Posted on: 2006/4/8 10:25
From Adelaide, South Australia
With a drag 1200 ute you could run in to the 9.90 zone with as little as 360hp flywheel.
Posted on: 2006/4/8 12:23
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
« 1 (2)
