Pearl paint???
Quite a regular
Just wondering my 1200 ute ill hav pearl in the clear, wen it gets resprayed, its for work and a street ride, dose neone know how well the pearl will hold up getting knock around????
Base color white or maybe black straight panels.
Posted on: 2006/3/31 7:09
Re: Pearl paint???
From sydney,Australia
are you getting a 3 layer pearl? the pearl will always hold up it is the clear that will get scratched just like any car does. when the peral is sprayed it is sprayed over the basecoat(color) then pearl then the clear hence the name 3 layer pearl.
Posted on: 2006/3/31 8:19
Re: Pearl paint???
You must use a daaaam lot of pearl.
Pearls can be mixed with the colour or more commonly are mixed in the clear.
Pearl is only paint. So it will only hold up aswell as normal paint does.
Before you go the white base with pearl, I recommend you check out a few cars painted white with pearl. I dont think I have ever seen a car painted white with pearl that didnt just look like dirty white paint. Check some out and see if you like it before you paint it.
Posted on: 2006/3/31 8:28
Re: Pearl paint???
From Albany creek Brisbane
u can get a ice pearl that won't give that egg shell look from house of color
Posted on: 2006/4/2 12:50
Re: Pearl paint???
From Townsville
When i had my corolla repainted white with a blue pearl it turned out a bone colour with blue pearl, which still turn heads but still a dirtier colour then what i wanted.
Be sure you get what you want!!!!
Posted on: 2006/4/2 16:37
Re: Pearl paint???
Quite a regular
From Southside of Brisbane
I have used pearl on a car mixed into the paint not in the clear and it came up quite good It also means you get a perfect paint ratio to pearl ratio and the clear is just clear which make touch ups a lot easier. I never tried to touch it p though cause it was on my race ute in townsville and we did a colour change on it after about 2 years as we need to fix all the panel damage from racing. As for white as a base and then pearl I think it might be ok is you mixed the pearl into a bright white paint but all the perals I have seen that have been in the clear coat have looked really dirty, this is generally because celar coat goes off after a while in the sun and changes the colour of the paint. similar to pine when it is clear vanarished and goes yellow after a year or two. I don't know of any clears that will not do that, though you could ask some panel beater I guess. My friend in townsville did his rx7 in a white but actually tinted the paint so it was slightly green which make the car look similar to glow paint colour with the gren and blus pearl over it, it looks pretty good as it hasen't gone a noticable dirty eggshell colour as the green masks the clear gong off.
Anyway just my to cents worth.
Posted on: 2006/4/3 7:58
Lead
Re: Pearl paint???
The better quality clears like Glasurit don't yellow. Best pearl paintjobs, simply use a pearl of a few shades lighter or darker of the same colour base coat. It gives the paint lots of depth. Mixing it in the clear means you look through the pearl. Mixing it in the colour, masks the pearl effect as the light isnt going through it to reflect. Sometimes this is more desireable as it gives a subtle pearl effect.
Posted on: 2006/4/3 9:20
