« 1 2 (3)
Re: Thoughts on high RPM
From Melbourne, Australia
i think your right, as with many things the application of the motor is going to determine what we want to acheive with its performance, and like you said huge torque is great for drag and also towing, one thing that may confuse you though is that rallycars have torque figures around 400-500Nm and although this seems to disagree with the formulas a Hp figure of 250 or so, though im not sure what revs it figure is at and this probably holds the answer
might have to reasrch that one!
Posted on: 2002/11/19 12:47
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Webmaster
From Lisbon - Portugal
Webmaster
Thanks, I allways liked phisics and I was learning how to work with java so I added a bit of datto and that came out, it's online since 1997 but it was hided deep in my first home page.
Hope you all like it
Many dream test runs were run on that. Now we have the engine but we lack the time.
daniel
Posted on: 2002/11/19 14:58
Keep them alive and sideways!
youve put the info for your car as standard as the initial values, but the temprature is 70 degress celcius, thats damn hot, is it supposed to be in faranheight (or however you spell that word)?
Posted on: 2002/11/20 1:26
1200 Coupe Rallycar
From Sydney
1200rallycar
The actual operating temp for an A series is 82 degrees celsius or 179 degrees fahrenheit. Remember, 100 degrees celsius is boiling, so 82 degrees is just hot.
Scott
Davo
Posted on: 2002/11/20 3:34
1200rallycar 70 degrees Celcius isn't that hot for an engine!
You will find most car with automatic electric fans they come on around 65 - 85 degrees Celcius!
Posted on: 2002/11/20 3:37
sorry i see now, i was thinking of ambient temprature (atmosphere) not running temp
Posted on: 2002/11/20 5:59
1200 Coupe Rallycar
So is it true or not with the old saying "Torques Cheap Lets Race!"?
That's a good one. Maybe I'll add it to my signature haha.
Posted on: 2002/11/20 7:18
That's about 300-370 lb-ft. Which sounds about right for a production 250hp 5.7 liter engine. If the rallycar has an engine half this size, it's probably un-naturally aspirated ...
Posted on: 2002/11/20 7:26
Webmaster
Webmaster
It is ambient temperature Damn! 5 years later you found a bug, the bad news is that I lost the source code in a hard disk crash so it would be hard to fix.
daniel
Posted on: 2002/11/20 11:48
« 1 2 (3)
