sounds like you just use a 180b crossmember and the gearstick comes out 10cm back, apart from that, alls good
I have done engine development to my 120Y from A12 through A15 to L18.
I used 610/710 crossmember, short L-series tranny from 160J which bolts in with(gearstick in right place after reversing stick F4W63, bented gearstick from 160J) tranny holder from B310 Sunny which needed little modification to holes, but was easy job to get all 4 bolts fit, and A10 160J propeller shaft which is perfect match to H165, only Centre Bearing support is something that I couldn't find where to get original, instead I modified 180B's to fit, 120Y's original bolt holes are much wider than 180B.
Something I tried to tell but didn't accomplish, there's two kind gearboxes to L-series engines, short and long ones, long ones need to centre tunnel modifications if used in 120Y, short boxes instead are perfect match without any modifications.
I used pretty wild L18 with 45 Dellor'tos, modified A87 head and about 340 degree cam with .65" valvelift, that produces about 180HP at 8500rpm and first time it gets traction it breaked wishbones so I replaced those with 160J wishbones, which are little too long and absolutely too rigid, and they still bent far too much under acceleration( those installation needed custom made king bolts). Have to do someday somekind shelby-rods. Also that H165 is too weak but I haven't found any good replacement yet.
Oh, I also take whole streering linkage and box from 180B, and also conmpele strut assembly from 180B( Actually I bolted everything under hood from 180B), it fits fine in with big coils, towers get tight only when increasing caster.
I also got brake booster from 810 180B as it sits directly in firewall letting more space to carburators, there's some lack of space with LHD machines.
I'll get some pictures ( that 120Y is nothing to be proud of except handling and power) when I get some digital camera to my hands.
