NIKKI CARB
From WESTERN AUSTRALIA
On my J13 engine it has an nikki carb does anybody know where the fuel,air, and idle screw are located on the carb.
Posted on: 2006/4/20 14:52
There Is No Substitute for Datsuns!]
1969 Datsun 521 J13 X 2
Re: NIKKI CARB
Please Help
Posted on: 2006/4/20 15:17
Re: NIKKI CARB
From Adelaide, Australia
Well most datsun carbs have the mix screw on the side of the carb closest to the head, there will be another screw to the rear of the carb that adjusts throttle.
Posted on: 2006/4/20 15:23
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: NIKKI CARB
sorry mate i forgot to check this on thanks for the help, are the scres big or small phillips or flat head.
Posted on: 2006/4/20 15:25
Re: NIKKI CARB
From Townsville, Qld
I find most carb adjustment screws are a bit of both
Posted on: 2006/4/20 16:32
Re: NIKKI CARB
From Merimbula,NSW, Australia
ive had three carbs in my life so far, and all were large flat head screws, if that helps, but all you gotta do is look, it wont be hard to find
Posted on: 2006/4/21 6:23
DATSLIFE
