First drive of A15ETT since my car got smashed... (1200rallycar)
From Melbourne, Australia
Hey fellas, so close to finished, took the new shell (ute) for a bit of a test run on wednesday night, very very exciting... it was overheating as the radiator was damaged in the accident, so it was a very short run, but as soon as i can replace the radiator i should be back in full flight!!!!
bought a sedan as a longer term project (stock looking sleeper, its half restored already, a12 auto) and just aquired back my friends coupe (which has all the good bits from my rallycar which i sold to him and never recieved payment)
still have the old rallycar shell too... i have to ditch a shell or two i think... anyone after a coupe shell with auto tunnel requiring some work in fixing up rust???
could possibly sell the sedan shell... am currently looing at options... but definately gotta make some room...
anyone interested in a ute with A15ETT? (another less likely but possible option)
anyway, blah blah blah
ill come good with some funky ute pics very soon!!!!
Posted on: 2006/4/28 12:37
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: First drive of A15ETT since my car got smashed... (1200rallycar)
From Canberra, Australia
Yes. Need pics very soon.
Posted on: 2006/4/28 12:41
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From SE Melbourne
Good to hear life is on the improve!
Posted on: 2006/4/28 14:30
Mildman, Datsunless
Got a new radiator in today, went for a bit more of a drive...
but am losing boost somewhere now and its way too wet out there...
the radiator is an awesome conversion... its out of a toyota paseo, about 690x400mm with plastic end tanks (but not alloy fins), with the same size hose fittings, both on the right hand side so you have to be a little tricky for the top hose (i used two hoses connected with an original 1200 heater hose t-piece that i blocked up the heater pipe with soldier), its twin core, and i have fit two 10inch thermo fans, with an intercooler in front of it. It still is holding the temp at just over a quarter (thermos are permanent wired at the moment)
other tips recently discovered, an old cylindrical coil is a great size for knocking in wheel bearing seals
coupe petrol level sensors are good for utes in that they have a built in breather pipe which is good for returning fuel into the tank (though the petrol gauge is now inaccurate)
oh yeah, and i have now personally fitted the bluey rear discs to a h165 diff and can verify that works (previously done it on h190 only)
and never assume cause it fit in one 1200 it will fit in the next!!!!! damn i had trouble making some stuff fit using all the components from the coupe bolting them into the ute, particularily the engine and crossmember, still dunno why that didnt go straight in
Posted on: 2006/4/30 12:37
1200 Coupe Rallycar
From Melbourne AUS
well done mate....
good to hear you have made some progress..
and good to have you back online
looking foreward to seeing the ute in action
Posted on: 2006/4/30 12:44
1973 B110 A12
