« 1 2 (3)
Re: California Datsun owners
Quite a regular
From San Diego, Ca
Hmm.. I can spare about $300-$400 for the suspension for now.
Is that his ID name on Ebay "Paul's Fab"?
Thanks for the help!
Posted on: 2006/5/4 1:09
1972 Datsun 1200 - B210 Engine/Tranny swap, 240z 14" Rims w/ Falken Azenis 195/60-14 tires....
From Burbank, CA
yes, that is his store.
you might want to save up and get the better setup. I had to buy it in parts for like a year.
bottom line - it's all better than stock especially if you have a 1200. too bad i just sold my old 81 210 front strut setup, it'd be a good starting place for a 1200. So maybe get a sunny front strut and all that good stuff and convert that, then it's all boltins ( sort of ... )
Posted on: 2006/5/4 1:59
|||\ 81 KPB310 /|||
From Burbank, CA
I've had to grind wheels to get them to clear brake calipers as well ;)
these things happen...
Posted on: 2006/5/4 2:04
|||\ 81 KPB310 /|||
Quite a regular
From San Diego, Ca
Would it be good to grind the calipers as opposed to the wheels? In my stock 1200 the caliper housing is sticking out about 3/4 inch from the rotors and this is what's hitting the rims...
I am contemplating of grinding it off to flush against the rotor so I can get my rims installed.... is this a good idea???
Posted on: 2006/5/4 22:41
From Burbank, CA
depends what you are grinding, and how much, maybe post a pic. if it's like what I think it is, then cutting it that much is probably not good. I had to make room for clearance of maybe 1 - 2 mm, and just 3 mm wide across each of the spokes where they start at the center where they're thick.
Posted on: 2006/5/5 0:35
|||\ 81 KPB310 /|||
« 1 2 (3)
