The original engine will either go to front the cost of the conversion, or go into a speedster project that I have always dreamed of doing. I love the boat-tailed speedsters of the 20-30's. The original engine is great if that is your desire, but it no longer is mine for this particular project. Although Riley two ports and Brumfield heads and such do indeed look great and function quite well, the cost has dramatically climbed over the past few years.
I can pick up a wrecking yard complete engine and tranny set up, do a bit of freshening up on it and have something that will do nicely for what my plans are. I can't begin to do that in the low buck mode for the stock conversion to full pressure oiling, high compression head, inserts and so forth.
How does the B-16/B-18's rate against the T3-C, R20 or R22 Toyota engines, as to HP? These can easily be bumped up to as much as 200 HP with some mods. The mods I'd be looking at are pretty limited to set of headers, possibly K&N filter and some new carbies. Remember, I am striving for a low-buck only approach.
Torque: I learned quickly in driving my Model A to never drive off from a dead start in the snow, in first gear. Your back end will easily pass your front end when minimal gas is applied. It is a feeling that is unexplainable, unless you have experienced it.
I originally started the project with a 321 engine in mind. Even got th etranny adapter and lots of old Rod mags when these engines gained favor in the early 70's. However, they are just too sparce in my neck of the woods, and fewer and fewer people seem to have learned about them. I like an engine that is not filled with modern day electronics. My Model A is Y2K compliant.
....a term people have not heard in a bit, I suppose. Just like my old '62 Falcon, '54 Chevy wagon, '42 Chevy coupe, etc.
No question the A will get boxed. I already have plans for that. Be interesting to see if the original suspension will need to have the wishbones cut or not. That is not always a given, so I'll have to see which engine I end up with before I do any splitting of the wishbones. Chassis Engineering makes and adaptor for the original suspension, if it is not to be cut. I am going to try to keep as much stock as I can. I'd love to have a tilt column and yet, keep the original steering wheel on it. (I personally love the original with its great size and unique feel in my hands). Part of the charm of the car was allowing my kiddo to ride on the running boards. Just hopping up on them had a unique feel over the years. I'll miss them in that regard, but have decided a fenderless, highboy-style sedan is what I want to experiment with for a low-buck cruiser.
No plans to chop the top or such. This car will have some overall weight reduction though. Original wheels, new engine and tranny will drop off some of the pounds quickly when comparred to the stock A stuff. Not sure if I'll fill the roof or not at this point. Personally, I like the soft top on her, but it needs repair/replacement, so I don't know if a hammered top is in the works or not.
Wish I had more time and car frames to put all the engine combos in I'd like to. It would be interesting to see just what some of the engines could actually do with a sedan. May surprise everyone in reality, but one never knows.
Where can I learn more about the L-16/L18 engines? Not turbos, as I am trying to not get any more complex than necessary. I have copied the pics of many of these engine modles from this site. Interesting in seeing them.
oops, gotta run.
Later,
Huey
