wtd 1:1 rising rate fuel reg- suited to carby
Quite a regular
iam chasing a pfr wich i can set the pressure at 4psi/
Posted on: 2006/5/11 10:25
Re: wtd 1:1 rising rate fuel reg- suited to carby
From campbelltown (sydney) australia
malpassi is the brand for you they are 130 bucks.most parts shops will be able to get it for you, i have one on my turbo a15 works great, just make sure u get a f/p gauge so u can set it, after that it works on its own.
you will need an efi pump to get the sort ofpsi u need. the malpassi is able to handle these high pressures just fine.
Posted on: 2006/5/11 10:38
* caution, sunglasses must be worn to view my ca18det *
Tyrie bought one off me that I dont think he is planning to use.
Maybe try him if you want secondhand
Posted on: 2006/5/11 10:42
Quite a regular
kegs do you have to get a special malpasi or can u just use the efi one? cheers
Posted on: 2006/5/14 7:48
well if its going to be used on a carby engine then u buy the carby one ...
Posted on: 2006/5/14 10:41
