EFI on A series engines?
Not too shy to talk
From malaysia
sorry if this question has been raised up before...any a12 that comes with EFI? ive seen the tech section and only found out that A14 and A15 that comes with EFI. any stock a12 EFI dattos?
i've heard that in malaysia there are used a15 EFI halfcut engines from japan for sale sometime ago...i think they should come from vannettes and its probably programmed for a van use and it wouldnt suit lets say, a b310?...the ecu is reprogrammable right? thanks for your replies
Posted on: 2006/5/11 17:58
Re: EFI on A series engines?
From Burbank, CA
getting an efi manifold is the hard part. Then you need the control box(ecu), no reason to use the oem one.
efi generally has an o2 sensor, so it's somewhat self adjusting.
Posted on: 2006/5/11 19:30
|||\ 81 KPB310 /|||
it can be done there is a guy in sydney called injection perfection all up it costs about 4 or 5 grand so it is usually better to go with a ca conversion or go the L series and you can get efi set ups for them a bit cheaper
Posted on: 2006/5/11 23:54
Not that any of us have ever heard of.
Highly unlikely. OEM systems are not reprogrammable. Some (like GM) can have the program chip replaced, but I wouldn't call that reprogrammable.
But it doesn't really matter. Like B210sleeper say, it will adjust. You can use a Sylvia S110 ECU and airflow meter and it will work on an A12. There are some right here in this club doing the same thing.
Posted on: 2006/5/12 5:19
