Ca 20 gearbox on ca18det?
Hi Went to put the flywheel on my ca18 that came with it. It didn't fit It only has 6 holes where the ca crank has 8 holes.
I have a ca20 gearbox out of a bluebird, so if i get a ca18 flywheel and clutch will it fit?
Posted on: 2006/5/21 9:27
Re: Ca 20 gearbox on ca18det?
You definitely can use a CA20 box on the CA18 but you will need the CA18 clutch and flywheel.
A lot of guys with bluebird retain the CA20 box because it makes the conversion very straight forward with everything bolting back onto stock mounts.
The problem is that the CA20 box won't hold up to nearly as much abuse as the CA18.
Posted on: 2006/5/21 10:32
From Melbourne Vic
yep
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
how much weaker?
Posted on: 2006/5/21 10:39
From Melbourne Vic
its sorta like having a 4spd standard datto box behind your a series carby turbo. you can drive it, and sorta hard, but it will break.
Posted on: 2006/5/21 10:41
Ok so find a ca18 one.
Posted on: 2006/5/21 10:44
