hard starting 1200
Quite a regular
From JUNEE NSW AUSTRALIA
g,day
my 1200 is very hard to start when cold , it turns over about 20+ times with the choke on before it fires, after it reaches operating temp it starts with first turn of the key it idles at 750rpm , rev,s fine timing is set at 6 degrees by timing light new plugs points and leeds i have tryed 2 carbs still the same problem float level is 1mm just below the dot on the sight glass i am thinking electrical maybe something is not operating properly until hot....HELP.
Posted on: 2006/5/21 13:36
OLD DOGS CAN LEARN NEW TRICKS
Re: hard starting 1200
From Gold Coast
Time for a CA conversion.
Posted on: 2006/5/21 13:42
From Merimbula,NSW, Australia
get an msd, itll start first time everytime
Posted on: 2006/5/21 13:59
DATSLIFE
Make sure that the choke butterfly is actually closing when you pull out the choke knob. The butterfly is controlled by a spring & if the shaft is stuck, as it was in my son's coupe, you only THINK that the choke is working. A little WD40 & some working the butterfly back & forth freed it up & everything was sweet after that.
Posted on: 2006/5/21 14:12
Love your Datsun.
Treat it well.
Quite a regular
whats a msd excuse my ignorance
Posted on: 2006/5/21 14:14
Not too shy to talk
From Guatemala, Central America.
Msd means "Multiple Spark Discharge" it's an ignition system that delivers several sparks instead of one single spark, Check MSD Ignition for more information.
Posted on: 2006/5/21 18:02
