(1) 2 3 »
CA18 speedo
From Gold Coast
What speedo cable are you guys running in your ca18 as the standard 1200 doesnt fit what is best to fit 1200 dash to ca box?
Posted on: 2006/5/29 11:43
Re: CA18 speedo
From brisbane, qld
Try looking at a vl commodore cable, or an early model skyline. hope this helps.
Posted on: 2006/5/29 11:55
Re: CA18 speedo
From Gold Coast
Thanks is what your running?
If so was there much modifying?
Posted on: 2006/5/29 11:58
Re: CA18 speedo
From Gold Coast, Australia
120Y cable. 300m longer than standard 1200 one. unscrew the electric device and screw the analogue one in.
Posted on: 2006/5/29 12:06
Re: CA18 speedo
From brisbane, qld
should be straight fit, mines not running yet!
120y could be the go as well?
Posted on: 2006/5/29 12:12
Re: CA18 speedo
it is the go. works in my brothers ute.
Posted on: 2006/5/29 12:14
Re: CA18 speedo
From Gold Coast
Thanks ill start hunting around for some to try.
Re: CA18 speedo
From Ipswich,QLD
So your doing a ca18 conversion if you run the ca box to the 1200 dash the speedo will be way out .why dont you just use the sylvia dash cluster would be heeps less work also you will have the rest of the other gauge such as temp ,RPM .
Posted on: 2006/5/29 12:30
Re: CA18 speedo
From Gold Coast
Allready did the conversion.
Posted on: 2006/5/29 13:27
Re: CA18 speedo
what analogue driver are you guys using?
Posted on: 2006/5/30 4:07
(1) 2 3 »
