« 1 (2)
Re: USA made 1976 honeybee carburetor help???? pleeeeeeeeze!
Quite a regular
From Mira Loma Ca. USA
B210sleeper wrote:
you probably don't need smog inspections anymore, get a weber!
If it is a 76, you still need to have a smog check. So, don't get rid of it yet! The choke will not make the carb "wet" it will smoke like a b!tch! Tip on rebuild... Pay someone with alot of experience. That particular carb is one of the hardest nissan ever made to rebuild right. If you do it, TAKE YOU'RE TIME!!! try to put parts in order.
Posted on: 2006/6/27 7:16
? It is a fairly simple carb (except for the linkage on the outside).
Agreed on the fuel level. Just look in the sight glass. If it is too high, the problem is the float & valve, nothing very complicated. If it is low, crank the engine for 30 seconds to pump up the fuel level, then check it again.
Another problem could be a bad head gasket making it wet inside. Do a compression test: it is simple and easy to do.
Posted on: 2006/6/27 7:47
ack! i cleaned up the carbie, but now i think i want to just stick the weber dgav on it, i just need an adapter plate for the manifold. anyone have the dimensions or an extra adapter for sale? should i just have it fabricated?
ty
Posted on: 2006/6/28 0:46
Weber 32/36 Carburetor tech section article. You can buy an adapter from Redline or various stores.
Posted on: 2006/6/28 16:22
« 1 (2)
