bored a14
hi im thinking of boring my a14 out but i was wondering whats the biggest you can bore it out to and i was also wondering is there any dangers in boring it out to big e.g will your block crack under pressure. Cheers jacob
Posted on: 2006/7/18 8:56
Re: bored a14
There are quite a number of people who have successfully bored these out to 79mm. That's 3mm or about .120" over standard. At this size, the metal between the end pairs of cylinders is getting a bit thin & for performance use, 'O' ringing the block is recomended.
Offseting the bores to try to keep this gap from shrinking too much is also a good idea, but if you are planing to run a street engine, then my personal recomendation is to keep it down to 77.5mm which is the third & largest stock oversize of 1.5mm
If you plan on a balls to the wall engine, then do it on an A15.
Posted on: 2006/7/18 11:05
Love your Datsun.
Treat it well.
Re: bored a14
i would get an a15 but i already put alot of time and money into my a14 but i want to be able to get the maximum power out of the a14 as possible thanks anyway that was very helpful
Posted on: 2006/7/18 12:35
Re: bored a14
also wht is the max horsepower you can drain out of a a14 without turbo or supercharge everything else consider
Posted on: 2006/7/19 7:31
Re: bored a14
140 - 150hp's not uncommon .... how deep are your pockets ??
Posted on: 2006/7/19 8:26
Re: bored a14
how deep do i need them to be?
Posted on: 2006/7/19 10:02
Re: bored a14
$2000 and up for the engine alone .... thats no bolt on bits - flywheel, clutch, exhaust, carbs, dizzy etc ....... all comes down to what you want at the end of the day ?? with the A series engines there's good value in big work on the head for flow and good balancing in the bottom for revs
edit. just found a quote for an A15 build i got a couple months back ....... wait for it .................. $2500 for the bottom end ......... and for the head ...... $1600. this was a good price and was happy to go with it but then a couple unforseen costs came up else where so the pin was pulled on the A15 upgrade ... for a while
Posted on: 2006/7/19 10:07
Re: bored a14
sounds good to me
Posted on: 2006/7/19 10:15
Re: bored a14
If you want to go with the A14, add the big pistons mentioned and use a larger-stroke crank from an A15.
It will cost less to buy a rebuilt A15 shortblock, and will give you more CCs than a bored A14. You can use all the other parts you already accumulated. So there's really no downside to going to the new block.
Posted on: 2006/7/20 3:31
Re: bored a14
From Bunbury Western Australia
I got a quote for honing an A15 block, fitting flat top ".020 oversize pistons, king bearings also ".020 oversize for machined crank mains and big end journals, balanced bottom end and also fitting my new camshaft.....$2600 for the bottom end alone!
I bought an A14 head which was a NOS item with huge intake ports, new valves, valve stem seals and performance valve springs with twin mikuni sidedraughts and the camshaft for $1250 which I thought was cheap.
It's the things I didn't calculate due to it being my first build up that caught me out, stuff like new sprockets, water pump, oil pump, electric fuel pump, pressure regulator, distributor, coil, extractors and exhaust system, radiator, thermo fan, diff upgrade, brake upgrade strut ugrade, big wheels and tyres to fit bigger brakes etc
It feels like I upgrade one thing then I have to change something else to make the upgrade work properly......But I love it because I am a sucker for punishment!
Posted on: 2006/7/20 6:04
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
