atdi
You're on the right track, but you just need some fine tuning
[img align=left]http://datsun1200.com/modules/myalbum/photo.php?lid=8530[/img]
This is actually the URL for the page that the photo is on & as you can see, it doesn't work.
If you right click on the actual image itself, you will get a list. Click on the 'properties' option at the bottom of the list. [try this on the image below]
The resultant popup box will have the actual URL of the image itself.
Highlight this URL & 'copy' it. Close down this box & get back to the 'message' box where you write all this stuff. Go through the motions that you have been correctly doing & you should get this,...
[*img align=left]http://datsun1200.com/modules/myalbum/photos/8530.jpg[/img*]
I included the *'s to stop it from posting the image, so they will not be there when you do it. Notice that the URL of the image is very similar to the URL of the page that the image is on. Close, but no banana.
The right URL will have the jpg. suffix.
Have another try & keep using the 'preview' button so that you can correct any errors without anyone knowing that you made a little faux pass. [screw up]
When you have it all just the way you want it, that's when you press 'submit'
