lumpy cam question?
From southern sydney "the shire"
what does a lumpy cam do and acheive?
Posted on: 2006/8/3 10:35
Re: lumpy cam question?
From Adelaide, Australia
Im no guru but, lumpier generally means the cam holds the valves open longer and opens them further, technically correct, length they are held open is referred to as duration, and height is referred to as lift.
Posted on: 2006/8/3 10:52
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From brisbane, qld
A 'lumpy cam' increases the distance your valves are opened and how long they are opened for thus increasing the amount of fuel allowed to enter the combustion chamber in a cycle and the amount of spent fuel to exit the chamber in that same cycle. this allows more power to be made by burning more fuel each cycle.
Posted on: 2006/8/3 10:57
are they any good on a stock carbie? or do they only work good with a webber ect
Posted on: 2006/8/3 12:05
From brisbane
i have a turbo grind cam with a stock carbie, it works, might be a bit quicker if you used a different carbie though...
Posted on: 2006/8/3 12:07
From Sydney Australia
Does anyone know whereabouts you would get one for an a14 from?
Cheers, Ian
Posted on: 2006/8/3 12:46
From brisbane
mines a camtech, so i dunno... try them, see what they've got for a14... (02) 9755 3101
Posted on: 2006/8/3 13:03
Most places will do a regrind on your existing cam or need one for exchange.
I think it costs around $100 for a cam grind, most places will have many to suit a-series.
Posted on: 2006/8/3 13:07
IPRA Build
if i were to put this cam on what would be a good carby upgrade?
P.S. in not after any power house its an A12
Posted on: 2006/8/3 13:09
From brisbane, qld
You could try one of the xf type webers or similar type weber, or maybe just rejet the original, or try a 40mm sidedraft weber
Posted on: 2006/8/3 13:52
