polishing rocker cover
Quite a regular
how and what would i use to polish my a12 rocker cover
Posted on: 2006/8/1 11:46
Re: polishing rocker cover
From melbourne
If it is steel (std) paint or chrome plate
If aluminiun(rare) pollish with autosoi
Cheers
Posted on: 2006/8/1 11:56
A14 1000 coupe road car
A15 1000 coupe race car
A10 1000 ute mat black (rat ute)
1000 wagon 4age 20 valve(next project)
From Melbourne, Australia
Yeh well funenly enough i just polished mine today and mine was a steel one all u need is a bench buffer and time. start by stripping off all the old paint off it and sand it with like a 400grit wet paper first to remove and rust.
cheers
Posted on: 2006/8/1 12:43
Quite a regular
got any pics chris1200t
Posted on: 2006/8/1 12:56
Na but ill get some like tommrow or sumthing but it looks like chrome really
Posted on: 2006/8/1 13:16
From Dallas TX
I went through this but in the end I wasn't able to get a good clear coat on it to keep it from rusting. Aluminum is easy but steel rusts so quickly especially when it gets hot. I tried to coat it with POR-15's "Glisten PC" clear coat that is designed for clearcoating polished steel and other metals. But it was very difficult to apply. I think it needed to be thinned much more than they suggested and then it would need multiple coats. Don't expect to spray a rattle can clear on polished steel because it won't hold up. It has to be an absolutely air/watertight seal otherwise the cancer will get in and it will spread.
Here's mine in the process of polishing: pic #1 I went through several grits of sandpaper by hand up to I think 1000, then 2 different buffing compounds down to a very fine grit, then polished with POR-15's "Artisan" polish (very very good polish by the way - highly recommended!!!)
Here's a pic on the engine: pic #2 You can't see it here but it is already starting to rust under the clearcoat. But now I have a spare valve cover and if I ever get time I'll probably just clean it up and paint it :) In my opinion it's not worth the time and effort because of the difficulty keeping the rust away.
Good luck.
Michael
Posted on: 2006/8/1 14:11
From Bunbury Western Australia
what about using one of those electronic rust proofing systems? would that work at keeping the rust away? I know it's a bit expensive for keeping the valve cover shiny but theoretically would it work?
Posted on: 2006/8/1 14:37
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Quite a regular
im currently polishing a RB30 alloy rocker cover and for the most of it im gonna use an electric sander so my question is what type of sander is suitable is a random orbit sander ok and what paper range do i use (eg) 120 grit to 400 grit or what
Posted on: 2006/8/5 1:09
From Burbank, CA
what about that ceramic stuff for exhausts - it's silver and looks shiny???
Posted on: 2006/8/5 1:49
|||\ 81 KPB310 /|||
Quite a regular
na its not the same
Posted on: 2006/8/5 3:59
