« 1 2 (3)
Re: got new motor finished
From Adelaide, South Australia
dd: who needs 40mm valves when u have a gt28 running 14psi...
Anyone can put boost in to an engine and get it to make power.
N/A engine building is and artform with very few people in the world that fully understand how to build a big HP N/A engine.
Posted on: 2006/8/3 18:03
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
From Las Vegas USA
Autocross isn't the place you want a big turbo motor. I still considering doing the A14 crank in A12 block to stay true to the class I run.
Tom
Posted on: 2006/8/3 18:32
From Tracy ,Ca
the dia of the valve pockets in the pistons are 2.060"
Posted on: 2006/8/3 22:20
From Tracy ,Ca
ok I ran my first event with new motor
The motor pulled from under 4 all the way to 8 were I had set my rev limiter enginge builder said should be good to 9 , I will reset limiter to 8600 next event the car was very traction limited with the increased torque
Posted on: 2006/8/7 6:09
« 1 2 (3)
