REAR DRUM SIZE
HI guys
I have checked out the tech section and cant seem to find any info on the size of the rear drums that are STD on a 76 1200 ute. I need to get at least 230mm size for engeniring any advice would be greatly appreciated
Posted on: 2006/8/9 6:45
Don't You Just Love Owning a Road Registered GOKART
Re: REAR DRUM SIZE
From Sydney, Australia
THe 1200 ones are wimpy. Use 180 Wagon Drum brakes.
I am full of good info.
Posted on: 2006/8/9 7:07
Re: REAR DRUM SIZE
From Gold Coast, Australia
is using the TRX disc conversion an option? will the 180 wagin drums bolt up? i know where a set of trx discs and claipers are available. let me know if you want to look ito it more and i can get more info for you. your in sydney right?
Posted on: 2006/8/9 7:15
Re: REAR DRUM SIZE
yeah im in sydney thru the day and wollongong at night.
I would be interested in the TRX disc brake conversion what $$$ do you think it might be. I am about to order the R31 set from datsport for the fronts ( I will have a complete 120y disk brake front end for sale shortly )
Cheers
Dave
Posted on: 2006/8/9 7:48
Re: REAR DRUM SIZE
The 180 wagon drums fit directly onto the H165 ute diff. No mods required.
Posted on: 2006/8/9 8:31
Re: REAR DRUM SIZE
is that the drums only or do you need the backing plates too? would this be the same size as a h145
Posted on: 2006/8/9 10:21
Re: REAR DRUM SIZE
From Adelaide, Australia
You need the backing plates, you can also use H165 stuff out of a stanza, same size, 200b i think as well. Then you could use Z-Car alloy rear drums to help with overheating.
Posted on: 2006/8/9 10:26
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: REAR DRUM SIZE
Yeah, drums and backing plates
- wheels off
- back off brake shoe adjusters
- pull drums off the diff housing. You might need to use a 8mm bolt through the drum to get it off.
- get brake shoes off, don't lose any bits
- pull off handbrake cables from backing plates
- undo the brake lines to the backing plates using a 10mm spanner.
- undo the 4 bolts that hold the backing plates onto the diff housing.
- Using a slide hammer or hammer, pull the axle and backing plate out of the housing in one piece.
- pull the axles through the backing plate, and leave the axles with the car.
Posted on: 2006/8/9 10:47
Re: REAR DRUM SIZE
thanks for the help easy job might as well do it when im putting the R31 fronts
Posted on: 2006/8/11 9:57
