« 1 2 (3)
Re: eeek!!! help please
Ahh good stuff, I'll have some bedtime reading to do... much better then the latest issue of FHM!
pfft! who am I kidding?
Posted on: 2006/8/14 13:16
From mittagong
just a few thing you might like to consider when your doing the head gaskit 1. dont tip your carbie upside down when you have it off. 2. use a bit of copper gresse on exhust studs (it makes it easyer to take them off next time) 3.when tensioning the head start in the middle and work your way out from there one at a time and keep swaping sides 4.keep checking all the rods are in the rocker arms.(while you have the head off check the rods by rolling them on a peice of glass if they are not spot on find some that are)5.dont over tighten the rocket cover you may need to panel beat it first to make sure the gasket surface is flat. it is a good idea to get the head skimed it dosent cost much,imagine doing all that work then having to do it all again because you wanted to save a few bucks.hope the info helps. chris
Posted on: 2006/8/14 13:29
From SE Melbourne
I got my head checked (including the sealing of all the valves) and then 'decked' - shaved flat for $50 I believe...maybe a little more.
As a defense mechanism my brain acutally forgets how much I have spent on Datsun related stuff...my psychologist tells me if I were to ever find out how much I have really spent on Datsun I will actually fall into a catatonic state and not awaken until it is 1973 again.
Posted on: 2006/8/14 13:43
Mildman, Datsunless
Not too shy to talk
From Baltimore,MD.
what if you already screwed up step one there on the carb? what then?
Posted on: 2006/8/14 21:19
« 1 2 (3)
