Here is the dyno sheet...
The long figure was the original tune....
The lowest line was when I took timing out...
Green was the first run this time, purple was 1st lot of timing out and the brown was the last timing change....
I dont know what needle is in it, std??
We would pull the needle out, file a small flat on one side to let more fuel get sucked in and try again..., then again, then again etc till we got a reasonable mixture...??
we just used the old points dissy that was in there, removed the vac and mechanical advance and locked it solid....
Trust me there is NO rocket science involved, just simplicity and common sense... Seemed to work....
A mate helped me make the manifolds, it is time consuming so dont think youll do it in a weekend bcos you wont, unfortunately. Realistically probably took about 4-6 weeks of working on it quite regularly....
Dont reinvent the wheel, just get a size that suits you needs...
