« 1 ... 4 5 6 (7) 8 »
Re: Gearbox fill bolt - stuck!
From Adelaide, Australia
I reckon try the arse end approach, let us know if its successful!
You would have to gravity fill it from inside the car with a long hose and a funnel or coke bottle etc.
Go for it!
Posted on: 2006/8/23 13:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: Gearbox fill bolt - stuck! VICTORY!
From SE Melbourne
Well looked into the filling through the arse end approach...too hard need a hose with a maximum 5mm OD to get past the ouput shaft.
So had one last go at the bolt with my new secret weapon blowtorch + vicegrips.
VICTORY!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Heated up the housing again, then absolutely leant on the vicegrips with my feet and it cracked! You should have heard the car creaking on the axle stands.....but finally victory is MINE!
Check the pics
Posted on: 2006/8/26 10:15
Mildman, Datsunless
From Melbourne AUS
good work
what a relief
that filler plug was getting the better of us all!
Posted on: 2006/8/26 11:17
1973 B110 A12
From Brisbane
Dont over tighten it when you put it back in
Posted on: 2006/8/26 11:31
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
From SE Melbourne
Defintely wont overtighten it! Even put a little grease on the thread to assist in the next time it needs to be undone.
Appreiciate everyone advise on this saga - it was the vice grips in the end that performed better than the stillson wrench.
Posted on: 2006/8/26 13:12
Mildman, Datsunless
From Sydney
im going to go have a drink
Posted on: 2006/8/26 14:31
When I get mine out, I will put some of that silver stuff on the threads (anti-seize).
Posted on: 2006/9/3 7:20
From SE Melbourne
Looks like it was perseverance that sorted it for me in the end...heat, pentrant spray - and it seems vice grips hold on much better than spanners, and even those Stillsons - so tough it out ddgonzal I was thinking of giving up a number of times....
I'll have a drink when yours comes out too!
Posted on: 2006/9/3 7:57
Mildman, Datsunless
i was already drinking but now fix that damn rust ben!!!!!! get navmanjnr onto it... stat!
Posted on: 2006/9/3 11:16
From SE Melbourne
Yeah yeah we'll get to the rust.....I think the windscreen takes priority!
Posted on: 2006/9/3 11:46
Mildman, Datsunless
