And what is the diffrence>
Not too shy to talk
From Seattle Washington USA
between replacable and non-replaceable u-joints...which is the best choice?
Posted on: 2003/1/12 3:41
Re: And what is the diffrence>
I think there is no choice -- the tailshaft either has one or the other.
Replaceable is better, as you can just change them when they wear out. With non-replaceable, the tailshaft has to be rebuilt. Well, sometimes. Some cars that have "non-replaceable" joints can actually be replaced by the do-it-yourself.
1200s have replaceable u-joints:
Posted on: 2003/1/12 5:17
From Melbourne, Australia
i got a tailshaft made for my h165 (rather than trying to find a ute one) and the guy that did it was showing me that the front uni-joint is quite small and not replacable, he said this is a weak link for high power engines, he machined out the mounts for the u-joint and put a larger replacable u-joint in and also the rear he put a replacable in so i can change the uni joints at home when required (quite easy really)
Posted on: 2003/1/12 8:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Hey PW, the H165 is the bigger differential in newer B120s.
There's been some controversy about this, but apparently 1971-1973 1200s (B110s) have replaceable u-joints.
Posted on: 2003/1/12 20:45
From Adelaide, Aust
While were on the subject of uni joints, ive converted my auto to manual, ive but in the clutch, clutch pedal & gearbox and am in the process of making a new crossmember. my problem is the tailshaft i have for my manual wont fit the diff, it seems the joints are bigger in the autos. how can i fix this problem.
Posted on: 2003/1/13 20:55
hmmm im thinking only way that could be is if the diff was a borg warner from a 120y, does the diff centre come out the front or back of the diff housing
ive done conversion with no probs
Posted on: 2003/1/14 10:55
1200 Coupe Rallycar
