« 1 (2) 3 4 »
Re: COIL-OVER KITS
From Adelaide
Laney, they will fit your struts no worries, depending on what strut tops you are using,you may have to drill the spring top hat slightly. (very simple process)
Scott
Posted on: 2006/9/17 14:03
Re: COIL-OVER KITS
From Sydney, Australia
Ok, so for the price I'd get:
1. 2x threaded part to be welded to strut.
2. 2x spring holder top/bottom and lock ring.
3. 2x adjusting spanner (got to lock them)
I can get the springs made locally.
But I'd be looking to get as much of the other bits as possible. Time is my biggest enemy.
Can you quote the delivery to my sydney address via PM or email?
I'm running the 180B struts which have the "larger than 1200" strut tubes. I'd guess they'd be same as stanza.
Regards,
Chris
EDIT: This is correct on what the deal includes.
Posted on: 2006/9/17 14:28
Re: COIL-OVER KITS
From Newcastle
hey champ yeh ill get a set im runnin camber tops will this make any difference? and how much r springs?
cheers budy
Posted on: 2006/9/18 12:20
Re: COIL-OVER KITS
From Adelaide
Dattodude.
I PMed You.
Posted on: 2006/9/18 13:45
Re: COIL-OVER KITS
I've already paid
Posted on: 2006/9/18 13:46
Re: COIL-OVER KITS
From Adelaide
Laney, Let me know what the inside diameter of the pillow ball that your tops have, as i do have a componet that i use for my tops. Sorry i dont supply springs, but you can get them from a lot of suspention shops. They suit 65mm springs.
Scott
Posted on: 2006/9/18 13:51
Re: COIL-OVER KITS
From Adelaide
Thank Chris
Posted on: 2006/9/18 13:56
Re: COIL-OVER KITS
Quite a regular
Put me down for a set :)
How long will the threaded sleeves be? as in how much height adjustment are we talking?
any pics?
Posted on: 2006/9/18 14:10
Re: COIL-OVER KITS
PM sent
Posted on: 2006/9/18 15:13
Re: COIL-OVER KITS
From Adelaide
b110coupe, the sleeves are 100mm long, which will give you enough adjustment. I'll get some pics on tonight, i have some in my photo album too.
Scott
Posted on: 2006/9/19 8:36
« 1 (2) 3 4 »
