Exhaust Help
From Adelaide, SA
hey guys looking to get a CA18 in my car soon also looking at changing the current exhaust to a 2". Would the CA run well on the same 2" or should i wait leave the exhuast and get a 3" when i change the motor. cheers
Posted on: 2006/9/27 1:32
Re: Exhaust Help
From Central Vic
it really depends on your pocket
you dont have to have a three inch system even if turbo
ive seen a couple of big power turbo cars make do with a 2 1/4 system really only a loss of power in the very top end
Posted on: 2006/9/27 1:45
to buy or not to buy???? OK
This is the reason I have five coupes
Re: Exhaust Help
From Adelaide, SA
Yer i dont really want to be changing exhaust twice but u cant run a 3" of a 1.2ltr. See what the guys at profix say
cheers
Posted on: 2006/9/27 1:56
Re: Exhaust Help
From Central Vic
if you get them to flange the system at the muffler and use a straight through center muffler you can then have just the engine pipe changed when you go to the better engine
this would be enough
Posted on: 2006/9/27 2:00
Re: Exhaust Help
From Adelaide, SA
thats basically what is was thinkin, but i wasnt sure weather a 2" would perform. i dont plan on doing alot to the motor origonally just wanna get it in and running. i suppose a 2" is still bigger than a factory CA18 setup.
Posted on: 2006/9/27 2:04
Re: Exhaust Help
From Central Vic
are you going turbo ??
Posted on: 2006/9/27 2:06
Re: Exhaust Help
From Adelaide, SA
Yer, definatley if i gonna change the motor mite as well put a turbo. i know most turbo cars run 3" thats why i asked.
Posted on: 2006/9/27 2:09
Re: Exhaust Help
From Central Vic
On a standard Ca18det a seperated dump pipe to 2 1/2 inch then to the two inch rear you would hardley notice the difference on the road
Posted on: 2006/9/27 2:11
Re: Exhaust Help
From Adelaide, SA
Thats exactly what i wanted to hear, cheers
Posted on: 2006/9/27 2:12
